It is currently Mon Jul 13, 2026 12:59 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun Feb 24, 2013 7:11 pm
Im after the sensor from the dizzy. New or used I dont care.
Its from a 92 16B vit engine
Post Posted: Mon Feb 25, 2013 10:41 am
What's up with that one mate? These are one of the most robust sensors out there! Only real way to kill them is with physical impact. If it is actually buggered you can also source them out of 1.3L dizzy's. Just have to remove the ignition coil amplifier which is also soldered on.
Dan
Post Posted: Mon Feb 25, 2013 8:38 pm
One of the wires is chopped and I didnt want to have joins in them (just another place to get a defect)
Post Posted: Mon Feb 25, 2013 8:44 pm
Defect? If you doing the engine conversion you will have other joins and cuts in the wiring. If soldered properly and covered in heat shrink you wont have any issues. If your not up to that I'm sure I could help you out.
Post Posted: Tue Feb 26, 2013 7:29 pm
I'm up to it no worries about that and that's what I will do if I cant get one, thanks for the offer though. I just dont like soldering joints in the bay where it can get hot
Post Posted: Mon Jul 28, 2014 4:45 pm
I need another one of these due to destroying it on the weekend.
I cant even find one online
Post Posted: Tue Aug 05, 2014 2:46 pm
I tried a sierra one but they are mirror image and cant be made to fit.
I would consider a whole distributor or even and engine if it comes to that
PM me with your options
Post Posted: Tue Aug 05, 2014 8:36 pm
Can you post up some pics of the sierra dizzy/module and vit dizzy/module
Post Posted: Wed Aug 06, 2014 6:21 am
Only if you have a spare vit one you can off load ha ha.
I'll do it when I get home
Post Posted: Sat Aug 09, 2014 3:09 pm
It worked, I used the coil from the sierra dizzy so I don't need one anymore
now time to go wheeling
Users browsing this forum: No registered users and 38 guests
