It is currently Wed Nov 04, 2026 11:01 pm
Post Posted: Tue Apr 09, 2013 4:24 pm
The Keyless entry is stuffed on the XL-7, the little buttons on the controller have come unsoldered and I don't have the skills to re-solder something that small.
What are the options??
Post Posted: Wed Apr 10, 2013 6:52 am
Either replacement remotes if you can find them (try ebay) or install an aftermarket alarm system with remote entry and wire it to the existing power locks - it might work out less expensive than the remotes.
Post Posted: Wed Apr 10, 2013 7:21 am
So you can get an Aftermarket one installed to do the same job??
I shoved my head under the dash but I could only find a thing that had Mitsubishi Electrics over it and a frequency.. Not sure if that was it..
Well after pulling some numbers off the thing I found out I was looking at the Immobilizer unit...
So where the hell is the central locking one ???
Vehicle: 2002 XL7
Post Posted: Wed Apr 10, 2013 7:12 pm
Mines been stuffed for ages magnat. If its just a cracked solder joint then appliance tech should be able to sort you for the remote.
Vehicle: 2002 XL7
Post Posted: Wed Apr 10, 2013 7:13 pm
And further to that I have never been able to find the unit for mine. I have a thread somewhere else bout mine but nothing's ever worked despite a number of suggestions.
Users browsing this forum: Google Adsense [Bot] and 255 guests
