It is currently Thu Nov 05, 2026 10:33 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Thu May 30, 2013 9:13 pm
SierraDan wrote:
Shave the housings top and bottom HEAPS haha.
Epic shave I tried Armsup
Post Posted: Thu May 30, 2013 9:40 pm
Yeah just like that haha.
Post Posted: Thu May 30, 2013 10:06 pm
The PCD Adapter/Spacer idea won't work with the Sierra hubs. They have a centre bore of 78mm, which won't clear the bolts retaning the rear drums or the mounting boss for the Free Wheeling Hub. You're going to have to go with a custom narrowed rear diff, and a tube or beam front axle with Mustang discs.
Post Posted: Fri May 31, 2013 11:21 am
Sounds like going RWD is gonna be a bitch...keen to see how you go.
That said, keeping mine 4WD, then engine/box swap has been a just as easy as any car.
Post Posted: Fri May 31, 2013 11:35 am
Going RWD isnt really that hard?
Post Posted: Fri May 31, 2013 3:54 pm
can't be that hard... pictures n shit here: viewtopic.php?f=4&t=18885
Vehicle: 1999 Jimny
Post Posted: Sat Jun 01, 2013 9:16 am
Was thinking of a 2wd slammed GV with one of the supercharged Holden V6s.... would be a fun. Easy enough to drop the front diff & other mods.
Post Posted: Sat Jun 01, 2013 11:54 am
JrZook wrote:
You could just cut and shut with a larger diameter tube, get rid of the pumpkin altogether.
Post Posted: Sat Jun 01, 2013 1:05 pm
They had Rwd jimnys/ sierras in Indonesia as well and most probably the rest of Asia I'd say. Could be a bit cheaper and easier to find than the states.
Vehicle: 95 Sierra
Post Posted: Sat Jun 01, 2013 11:26 pm
Thanks guys, awesome help. Loving these forums.
Man this little 1.3 drinks the fuel ! Maybe cause I have to ring it's neck to get around. I might pull the carby and see what's going on.
Post Posted: Thu Jun 13, 2013 1:22 am
Zook_Fan wrote:
Samurai's came out in a 2wd over in the states. They retained a transfer case of sorts which I assume just lowered hi-range but didn't have any low range or 4wd outputs. If you could source a 2wd front axle you might find it very easy to install and you would be loosing a lot of weight over the front that is redundant.
How about a Jimny 2wd front axle?
http://www.ebay.com.au/itm/SUZUKI-JIMNY ... 4ac4e0e91f
Post Posted: Thu Jun 13, 2013 8:16 am
It's worth pointing out that that is NT width- it's from a 660 jimmy which run no flares to comply with Kei class rules.
US sourced 2wd samurai front axles will be WT width.
Post Posted: Thu Jun 13, 2013 7:51 pm
Which could be useful if you wanted to run 8" front rims with massive offset for sic looks mate, or if you're a fan of the narrow fronted Drag Car/Funny Car looks with pizza cutter wheels.
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Fri Jun 14, 2013 10:33 pm
could he simply flip the leaves upside down and notch out the floor so it fits?
Users browsing this forum: Google [Bot] and 81 guests
