It is currently Tue Nov 03, 2026 9:58 pm
Vehicle: 85 WT with SR20DE N/A
Post Posted: Tue Jun 25, 2013 5:43 pm
Hey Guys,
I am trying to find the best way to flare my Jimny with chopped gaurds.
i tryed the normal flare you can buy from Clark rubber but nothing to screw to as the gards been chopped to much
any ideas be grate i don't really want to spend more than $200.
Vehicle: hkbjk
Post Posted: Tue Jun 25, 2013 6:56 pm
I will be doing this on mine shortly, I am going to knock up some propeller plate trims around the edge of the body where I cut the flares off, then make a small diameter tube frame to bolt to that time (the tube frame will be the outside edge of the flare) and then fill it in with sheet or propeller plate - I think it will be lucky to cost 150 - all you need as a grinder and a welder an some scrap
Post Posted: Tue Jun 25, 2013 7:02 pm
say no to propeller plate :gross:
Post Posted: Tue Jun 25, 2013 7:06 pm
When you do can you take lots of pics i can not quit picture it
Vehicle: hkbjk
Post Posted: Tue Jun 25, 2013 7:10 pm
:roll: a negative 2 cents reply from you? how unusual. It's quite tiring. Try to cheer up and realise that people have ideas and taste different to yours - offer constructive criticism if you think it will help out but I'm sure no one really gives a crap about all the comments that get posted regarding your dislikes unless they asked for them
Vehicle: hkbjk
Post Posted: Tue Jun 25, 2013 7:12 pm
yes it will all go in my build thread viewtopic.php?f=4&t=40934
Post Posted: Tue Jun 25, 2013 7:13 pm
Chequer plate is good for step treads and anywhere else looks tacky and cheap and is usually dangerous IE door trims.. Yay cheese grater.
Post Posted: Tue Jun 25, 2013 7:27 pm
X2
Also seeing as its shiny the plod might be onto you fairly quickly over it...
Post Posted: Tue Jun 25, 2013 7:29 pm
looks like i'm not on my own :thefinger:
checker plate brings all the boys to the yard pompoms pompoms
Post Posted: Tue Jun 25, 2013 7:38 pm
any oe have pics of what they have done ???
Vehicle: hkbjk
Post Posted: Tue Jun 25, 2013 7:57 pm
X2
Not leaving it bare - am painting it so it won't be too much of an eye sore. It will either be that or just flat sheet but ill see what is available when I go to do it
Post Posted: Tue Jun 25, 2013 8:01 pm
The only place checker plate is cool is on the front guards of a Land Rover, provided it's painted satin black.
Post Posted: Wed Jun 26, 2013 6:57 am
Has any one used the bush wacker flairs on a jimny
Post Posted: Wed Jun 26, 2013 9:25 am
If I get round to running more offset, ill be trying DBOR flairs, all rubber, and should just pop rivet or nutsert on.
Post Posted: Wed Jun 26, 2013 10:10 am
there is a white Jimny on here with them, i'd do some research before buying as they're expensive & fragile... lots of people report that they break easy.
viewtopic.php?f=4&t=35767
AMEN, praise the lord. :peaceout:
Post Posted: Wed Jun 26, 2013 10:14 am
*cough*, tube guards *cough*
Users browsing this forum: No registered users and 109 guests
