| Author |
Message |
hypactiv1
Joined: Tue Jun 07, 2011 1:53 am Posts: 203 Location: Darwin Townsville end of the year
Vehicle: 85 WT with SR20DE N/A
 Posted: Tue Jun 25, 2013 5:43 pm |
Hey Guys,
I am trying to find the best way to flare my Jimny with chopped gaurds. i tryed the normal flare you can buy from Clark rubber but nothing to screw to as the gards been chopped to much
any ideas be grate i don't really want to spend more than $200.
Xtreme
Vehicle: hkbjk
 Posted: Tue Jun 25, 2013 6:56 pm |
I will be doing this on mine shortly, I am going to knock up some propeller plate trims around the edge of the body where I cut the flares off, then make a small diameter tube frame to bolt to that time (the tube frame will be the outside edge of the flare) and then fill it in with sheet or propeller plate - I think it will be lucky to cost 150 - all you need as a grinder and a welder an some scrap
atari4x4
 Posted: Tue Jun 25, 2013 7:02 pm |
say no to propeller plate
hypactiv1
 Posted: Tue Jun 25, 2013 7:06 pm |
Xtreme wrote: I will be doing this on mine shortly, I am going to knock up some propeller plate trims around the edge of the body where I cut the flares off, then make a small diameter tube frame to bolt to that time (the tube frame will be the outside edge of the flare) and then fill it in with sheet or propeller plate - I think it will be lucky to cost 150 - all you need as a grinder and a welder an some scrap When you do can you take lots of pics i can not quit picture it
Xtreme
Vehicle: hkbjk
 Posted: Tue Jun 25, 2013 7:10 pm |
 a negative 2 cents reply from you? how unusual. It's quite tiring. Try to cheer up and realise that people have ideas and taste different to yours - offer constructive criticism if you think it will help out but I'm sure no one really gives a crap about all the comments that get posted regarding your dislikes unless they asked for them
Xtreme
Vehicle: hkbjk
 Posted: Tue Jun 25, 2013 7:12 pm |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jun 25, 2013 7:13 pm |
Chequer plate is good for step treads and anywhere else looks tacky and cheap and is usually dangerous IE door trims.. Yay cheese grater.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Tue Jun 25, 2013 7:27 pm |
want33s wrote: Chequer plate is good for step treads and anywhere else looks tacky and cheap and is usually dangerous IE door trims.. Yay cheese grater. X2 Also seeing as its shiny the plod might be onto you fairly quickly over it...
atari4x4
 Posted: Tue Jun 25, 2013 7:29 pm |
Xtreme wrote: :roll: a negative 2 cents reply from you? how unusual. It's quite tiring. Try to cheer up and realise that people have ideas and taste different to yours - offer constructive criticism if you think it will help out but I'm sure no one really gives a crap about all the comments that get posted regarding your dislikes unless they asked for them looks like i'm not on my own checker plate brings all the boys to the yard
hypactiv1
 Posted: Tue Jun 25, 2013 7:38 pm |
any oe have pics of what they have done ???
Xtreme
Vehicle: hkbjk
 Posted: Tue Jun 25, 2013 7:57 pm |
31zook wrote: want33s wrote: Chequer plate is good for step treads and anywhere else looks tacky and cheap and is usually dangerous IE door trims.. Yay cheese grater. X2 Also seeing as its shiny the plod might be onto you fairly quickly over it... Not leaving it bare - am painting it so it won't be too much of an eye sore. It will either be that or just flat sheet but ill see what is available when I go to do it
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Tue Jun 25, 2013 8:01 pm |
The only place checker plate is cool is on the front guards of a Land Rover, provided it's painted satin black.
hypactiv1
 Posted: Wed Jun 26, 2013 6:57 am |
Has any one used the bush wacker flairs on a jimny
31zook
 Posted: Wed Jun 26, 2013 9:25 am |
If I get round to running more offset, ill be trying DBOR flairs, all rubber, and should just pop rivet or nutsert on.
atari4x4
 Posted: Wed Jun 26, 2013 10:10 am |
hypactiv1 wrote: Has any one used the bush wacker flairs on a jimny there is a white Jimny on here with them, i'd do some research before buying as they're expensive & fragile... lots of people report that they break easy. viewtopic.php?f=4&t=35767sideways wrote: The only place checker plate is cool is on the front guards of a Land Rover, provided it's painted satin black. AMEN, praise the lord.
tanshi
 Posted: Wed Jun 26, 2013 10:14 am |
*cough*, tube guards *cough*
