| Author |
Message |
Pooke
Joined: Sun Nov 18, 2012 12:03 pm Posts: 66 Location: New Zealand
Vehicle: 95 SJ70, 96 Escudo v6
 Posted: Sat Jan 10, 2015 6:55 pm |
Right so I have a NGV 2.4 J24B, 4months ago I replaced the head after it cracked, Common problem I know. Well now Its gone and cracked the block! Also a relatively common issue. It hurts!!!!!!
Now I need another vehicle. So i'm looking at a V6 NGV instead. My questions, what is the H27A like? Any known issues? What do you think of them?
magnat
Joined: Sat Jul 28, 2007 11:30 pm Posts: 1066 Location: Southern Highlands N
 Posted: Sat Jan 10, 2015 7:06 pm |
Apart from Timing chain rattles and sticking lifters.... not much goes wrong with them ..
dougies_tx5turbo
Joined: Tue May 25, 2010 10:56 am Posts: 1051 Location: north brisbane
 Posted: Sat Jan 10, 2015 7:14 pm |
And they are petrol guzzlers
magnat
 Posted: Sun Jan 11, 2015 7:21 am |
I have not found mine to be too heavy on the juice.. Compared to a 6G72 in a Magna.. this engine sips fuel... 10l/100K on the Highway and around 15 in the city... in a 1.8T 4x4 is not too bad..
murcod
Joined: Thu Apr 16, 2009 11:30 pm Posts: 327 Location: Adelaide
Vehicle: XL-7 (gone) + Kizashi
 Posted: Mon Jan 12, 2015 10:06 am |
I'd go for the later model with the 3.2l V6 (I've got a H27A in a 2004 XL-7). It goes okay, but every time it's started there's a couple of seconds of rattling. They also seem very fussy on what oil filter you use - some will give you horrendous chain rattle. Last time I checked mine was getting just under 14l/100km in suburban Adelaide (with the 5 spd auto trans.)
Pooke
 Posted: Mon Jan 12, 2015 3:02 pm |
Thanks for the input guys. I really like the NGV so want to stick with one, not sure if this is madness or not, as I do about 60000kms a year. The 2.4 is just a complete pile of rubbish. So the 2.7 seems like it may be an option, I have considered the 2.0 but think it might be a little but gutless, unless they have improved since the original GV. and the 3.2 is is as rare as hens teeth, and right out of my price range.
tanshi
 Posted: Mon Jan 12, 2015 3:29 pm |
murcod
 Posted: Mon Jan 12, 2015 3:33 pm |
The fuel economy will hit you doing 60000km per year. What sort of economy was your J24B getting?
The H27A and the 5 speed auto go very nicely together (I assume the NGV drive train would be virtually identical to my 2004 XL-7?)
tanshi
 Posted: Mon Jan 12, 2015 3:45 pm |
you cant compare the xl-7 to the ngv.
for one thing the newer h27s have vvt where the older ones didn't I believe.
Pooke
 Posted: Mon Jan 12, 2015 3:47 pm |
Am getting about 12l/100km with the J24b. I do alot of open road stuff and with the 4speed its doing about 2700rpm at 100kms. From what I can tell the H27a might even work out cheeper to run, due to revving less I guess. Dad has one and on a 450km trip to Taupo for a family event he used $20 less each way than I did.
tanshi
 Posted: Mon Jan 12, 2015 3:59 pm |
yikes your running about 8.3 ks per litre?
I get about 9-10 per litre.
I only get 7 per litre towing my comp zook on a trailer behind it.
murcod
 Posted: Mon Jan 12, 2015 8:36 pm |
GeckoXL7
Joined: Tue Sep 25, 2012 8:12 pm Posts: 1173 Location: VIC
Vehicle: 2002 Suzuki XL7
 Posted: Tue Jan 13, 2015 8:18 am |
H27A main power difference has to do when the exhaust size went slightly larger, NGV would have ironed out any issues the XL-7's had. the timing chain rattle was fixed in mid 2002.
There is a big difference between the stock 2.18inch exhaust to the 2.5" exhaust. Not sure what the new GV has but prob 2.25" and also weighs less i would imagine so better fuel economy esp on the high way where ive read avg around the 9 and around 10-12 in the city. Also would have a nock sensor so make better use of higher octain fuel and different mapping over the xl-7
The H motors also self adjust so low maintenance, just take care of the oil, filters and normal maint and they last a very long time. Torque wise they are quite torquey down low and like to rev i have had mine down to around 400rpm and didnt stall on a hill climb. I would much prefer it over the later GM motor. Reason why monster used it in the Pikes hill challenge for soo many years even in the SX4 because it was a tough reliable motor that took a ton of abuse eg two turbos and close to 1000hp. and doesnt mind reving at 4500rpm all day as in the plains they use them in.
Would love the ngv H27A motor and auto transmision in my xl-7
murcod
 Posted: Tue Jan 13, 2015 9:16 pm |
GeckoXL7 wrote: Also would have a nock sensor so make better use of higher octain fuel and different mapping over the xl-7
Your H27A would have a knock sensor - I just checked on the Suzuki service manual for the first series XL-7.  The five speed auto would make the biggest improvement to your XL-7.
GeckoXL7
 Posted: Tue Jan 13, 2015 9:22 pm |
Yeah it does and seems to make good use of it. Never had the motor ping or knock before
I should of wrote that better lol. Or not go on this forrum on the dumb phone.
murcod
 Posted: Tue Jan 13, 2015 9:23 pm |
I edited while you were posting - the five speed auto (in place of your four speed) would make a huge improvement.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Jan 14, 2015 6:57 am |
3 NGV 2.7's with daily duties within my family. A couple of problems with one which were related to a dying catalytic convertor around 135k and no other issues. The other two have been flawless.
Pooke
 Posted: Wed Jan 14, 2015 7:26 pm |
I think I am going to go with a h27a seems like its been around long enough to have had all the issues sorted. Not like the dreadful j24b
b1nelly
Vehicle: 2007, GV, trekker
 Posted: Wed Jan 21, 2015 9:54 pm |
yeh mate. No issues at all with the H27a. just be aware that there is little to no performance parts for engine. The extractors are available but not worth (plenty of topics on here) as the standard headers are pretty good.
As for fuel, I get about 10 liters for 100 on the highway and 12 around town. I run 275/75 AT tyres and have a snorkel which made a good difference .
Engines are fussy about the filters, I'd recommend changing the oil filters every 7500kms the engine noise since i've started doing that has quietened right down.
Little low in the low revs torque, but they love a good rev.
GeckoXL7
 Posted: Thu Jan 22, 2015 8:25 am |
 meh to bellow
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Thu Jan 22, 2015 1:00 pm |
King of the add on's and additives. Macdaddy maybe gone but you sure do make up for his exhaust bullshit.
_________________ Chop
tanshi
 Posted: Thu Jan 22, 2015 1:04 pm |
Chop wrote: King of the add on's and additives. Macdaddy maybe gone but you sure do make up for his exhaust bullshit. but surely if I run a k and n, a hyclone, and fuel with ethanol in it I will get those extra 900 flexes im looking for wont I?
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Thu Jan 22, 2015 1:14 pm |
Only if they are stage 3.
atari4x4
 Posted: Thu Jan 22, 2015 6:32 pm |
damn, yousecunce should have quoted that shit.
MagiicMediic
Vehicle: Suzuki Grand Vitara 2006 2.7
 Posted: Sun Jun 28, 2020 10:59 am |
Just wondering. I have a JB627 and the engine has around 211,000kms. Are there any long term issues with this many kms I should worry about? Also, might be due to the poor filter, I get around 12.8l/100kms in town and around 10.5-11L/100km on the highways. Any way I can bring it back down a bit?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Sun Jun 28, 2020 5:07 pm |
From everything I've seen, that economy is normal.
MagiicMediic
 Posted: Sun Jun 28, 2020 5:40 pm |
Gwagensteve wrote: From everything I've seen, that economy is normal. Ok. I guess then its a thirsty little V6. Nothing worth complain too much about. I've out performed some GQ patrols in the little Zook
