It is currently Mon Oct 19, 2026 3:09 am
Vehicle: 95 SJ70, 96 Escudo v6
Post Posted: Sat Jan 10, 2015 6:55 pm
Right so I have a NGV 2.4 J24B, 4months ago I replaced the head after it cracked, Common problem I know. Well now Its gone and cracked the block! Also a relatively common issue. It hurts!!!!!!
Now I need another vehicle. So i'm looking at a V6 NGV instead. My questions, what is the H27A like? Any known issues? What do you think of them?
Post Posted: Sat Jan 10, 2015 7:06 pm
Apart from Timing chain rattles and sticking lifters.... not much goes wrong with them ..
Post Posted: Sat Jan 10, 2015 7:14 pm
And they are petrol guzzlers
Post Posted: Sun Jan 11, 2015 7:21 am
I have not found mine to be too heavy on the juice.. Compared to a 6G72 in a Magna.. this engine sips fuel...
10l/100K on the Highway and around 15 in the city... in a 1.8T 4x4 is not too bad..
Vehicle: XL-7 (gone) + Kizashi
Post Posted: Mon Jan 12, 2015 10:06 am
I'd go for the later model with the 3.2l V6 (I've got a H27A in a 2004 XL-7). It goes okay, but every time it's started there's a couple of seconds of rattling. They also seem very fussy on what oil filter you use - some will give you horrendous chain rattle. Last time I checked mine was getting just under 14l/100km in suburban Adelaide (with the 5 spd auto trans.)
Post Posted: Mon Jan 12, 2015 3:02 pm
Thanks for the input guys. I really like the NGV so want to stick with one, not sure if this is madness or not, as I do about 60000kms a year. The 2.4 is just a complete pile of rubbish.
So the 2.7 seems like it may be an option, I have considered the 2.0 but think it might be a little but gutless, unless they have improved since the original GV.
and the 3.2 is is as rare as hens teeth, and right out of my price range.
Post Posted: Mon Jan 12, 2015 3:29 pm
I love my 2.7 manual NGV
Post Posted: Mon Jan 12, 2015 3:33 pm
The fuel economy will hit you doing 60000km per year. What sort of economy was your J24B getting?
The H27A and the 5 speed auto go very nicely together (I assume the NGV drive train would be virtually identical to my 2004 XL-7?)
Post Posted: Mon Jan 12, 2015 3:45 pm
you cant compare the xl-7 to the ngv.
for one thing the newer h27s have vvt where the older ones didn't I believe.
Post Posted: Mon Jan 12, 2015 3:47 pm
Am getting about 12l/100km with the J24b. I do alot of open road stuff and with the 4speed its doing about 2700rpm at 100kms.
From what I can tell the H27a might even work out cheeper to run, due to revving less I guess. Dad has one and on a 450km trip to Taupo for a family event he used $20 less each way than I did.
Post Posted: Mon Jan 12, 2015 3:59 pm
yikes your running about 8.3 ks per litre?
I get about 9-10 per litre.
I only get 7 per litre towing my comp zook on a trailer behind it.
Post Posted: Mon Jan 12, 2015 8:36 pm
I know the engines aren't identical, but going by Redbook the max power and torque outputs are the same (with the XL-7 developing max torque at 3300 vs NGV at 4500 RPM).
http://www.redbook.com.au/cars/research ... x=0&eapi=2
PS: The first series XL-7 did have less power.
Vehicle: 2002 Suzuki XL7
Post Posted: Tue Jan 13, 2015 8:18 am
H27A main power difference has to do when the exhaust size went slightly larger, NGV would have ironed out any issues the XL-7's had. the timing chain rattle was fixed in mid 2002.
There is a big difference between the stock 2.18inch exhaust to the 2.5" exhaust. Not sure what the new GV has but prob 2.25" and also weighs less i would imagine so better fuel economy esp on the high way where ive read avg around the 9 and around 10-12 in the city. Also would have a nock sensor so make better use of higher octain fuel and different mapping over the xl-7
The H motors also self adjust so low maintenance, just take care of the oil, filters and normal maint and they last a very long time. Torque wise they are quite torquey down low and like to rev i have had mine down to around 400rpm and didnt stall on a hill climb. I would much prefer it over the later GM motor. Reason why monster used it in the Pikes hill challenge for soo many years even in the SX4 because it was a tough reliable motor that took a ton of abuse eg two turbos and close to 1000hp. and doesnt mind reving at 4500rpm all day as in the plains they use them in.
Would love the ngv H27A motor and auto transmision in my xl-7
Post Posted: Tue Jan 13, 2015 9:16 pm
Your H27A would have a knock sensor - I just checked on the Suzuki service manual for the first series XL-7. :wink:
The five speed auto would make the biggest improvement to your XL-7. ;)
Post Posted: Tue Jan 13, 2015 9:22 pm
Yeah it does and seems to make good use of it. Never had the motor ping or knock before
I should of wrote that better lol. Or not go on this forrum on the dumb phone.
Post Posted: Tue Jan 13, 2015 9:23 pm
I edited while you were posting - the five speed auto (in place of your four speed) would make a huge improvement.
Post Posted: Wed Jan 14, 2015 6:57 am
3 NGV 2.7's with daily duties within my family. A couple of problems with one which were related to a dying catalytic convertor around 135k and no other issues. The other two have been flawless.
Post Posted: Wed Jan 14, 2015 7:26 pm
I think I am going to go with a h27a seems like its been around long enough to have had all the issues sorted. Not like the dreadful j24b
Vehicle: 2007, GV, trekker
Post Posted: Wed Jan 21, 2015 9:54 pm
yeh mate. No issues at all with the H27a.
just be aware that there is little to no performance parts for engine. The extractors are available but not worth (plenty of topics on here) as the standard headers are pretty good.
As for fuel, I get about 10 liters for 100 on the highway and 12 around town. I run 275/75 AT tyres and have a snorkel which made a good difference .
Engines are fussy about the filters, I'd recommend changing the oil filters every 7500kms the engine noise since i've started doing that has quietened right down.
Little low in the low revs torque, but they love a good rev.
Post Posted: Thu Jan 22, 2015 8:25 am
:roll: meh to bellow
Post Posted: Thu Jan 22, 2015 1:00 pm
King of the add on's and additives. Macdaddy maybe gone but you sure do make up for his exhaust bullshit.
Post Posted: Thu Jan 22, 2015 1:04 pm
but surely if I run a k and n, a hyclone, and fuel with ethanol in it I will get those extra 900 flexes im looking for wont I?
Vehicle: Which one?
Post Posted: Thu Jan 22, 2015 1:14 pm
Only if they are stage 3.
Post Posted: Thu Jan 22, 2015 6:32 pm
damn, yousecunce should have quoted that shit. :(
Vehicle: Suzuki Grand Vitara 2006 2.7
Post Posted: Sun Jun 28, 2020 10:59 am
Just wondering. I have a JB627 and the engine has around 211,000kms. Are there any long term issues with this many kms I should worry about? Also, might be due to the poor filter, I get around 12.8l/100kms in town and around 10.5-11L/100km on the highways. Any way I can bring it back down a bit?
Post Posted: Sun Jun 28, 2020 5:07 pm
From everything I've seen, that economy is normal.
Post Posted: Sun Jun 28, 2020 5:40 pm
Ok. I guess then its a thirsty little V6. Nothing worth complain too much about. I've out performed some GQ patrols in the little Zook
Users browsing this forum: No registered users and 295 guests
