It is currently Fri Oct 23, 2026 5:55 pm
Vehicle: 91 WT 1.6EFI
Post Posted: Tue Apr 07, 2015 2:04 pm
I have the common oil leak coming from where the distributor bolts to the head. Put in a new suzuki o-ring from suzistore, still there and the o-ring wasn't pinched. Hit it with permatex blue gasket stuff, lasted one trip and now leaks again. Anything else I can do?
Post Posted: Tue Apr 07, 2015 2:08 pm
im betting its leaking from some where else and running down
Post Posted: Tue Apr 07, 2015 2:16 pm
Not much else above it. Valve cover? I'll go have a look
Post Posted: Tue Apr 07, 2015 2:24 pm
Negatory. It is very clearly coming from the bottom of the distributor housing and spilling onto the water outlet housing.
Post Posted: Tue Apr 07, 2015 2:26 pm
I mean further up the distributor. if it ain coming out around the o ring cos you have fixed it, it must be coming from some where else
Post Posted: Tue Apr 07, 2015 2:35 pm
Ohh interesting idea. I'll check it out
Post Posted: Tue Apr 07, 2015 5:25 pm
The dizzy housing also houses the rocker shaft coming out the back of the head. Although the shaft has an oring near the end it goes hard and leaks oil so you also need to put some silicone around the housing there.
Post Posted: Tue Apr 07, 2015 6:39 pm
Found the leak, thanks tanshi. Spot the problem? Image
Post Posted: Sun Apr 12, 2015 4:19 pm
Big crack???
Post Posted: Sun Apr 12, 2015 4:30 pm
Yup all of the way around the outside sleve. Doesn't effect operation but oil is bypassing the o-ring.
Post Posted: Sun Apr 12, 2015 5:37 pm
Gee ok, dont think they are cheap either.
Post Posted: Sun Apr 12, 2015 6:07 pm
Ya its a bit of a bastard. I have found them between $180-$320. Might just set the timing and gasket seal it in to plug the leak for now. That won't be rough as guts.
Users browsing this forum: Google [Bot] and 95 guests
