| Author |
Message |
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Sun May 14, 2017 4:01 pm |
G'day AZ  I'm looking at swapping my SJ80 softtop body onto a NT 1.3 chassis i know the body mounts line up but is there anything else i need to be aware of? Also for a legal point of view am i aloud to do this? and will it need to be re registered or can i just use the rego from the SJ80?
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Sun May 14, 2017 7:14 pm |
You'll have to comply to the emissions standard of the 80. Using the new body you should be right. You'll need to comply to all ADRs of the later model.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Sun May 14, 2017 7:35 pm |
Surely you could get the links re-jigged with wt diffs for less effort and more gain ?
_________________ ...
Joe
 Posted: Sun May 14, 2017 7:58 pm |
MrRocky wrote: Surely you could get the links re-jigged with wt diffs for less effort and more gain ? That was the plan but my mate who does my welding is moving away so unless it all gets done in one weekend i end up left with out a car This way i can take my time and build the chassis up with ruf WT diffs have it all done and rolling then in one weekend swap my body and motor/gearbox over
MrRocky
 Posted: Sun May 14, 2017 8:06 pm |
Cant just slap a jimny diff in the front ?
MrRocky
 Posted: Sun May 14, 2017 8:08 pm |
Just seems alot of effort, how often are you wanting to do harder stuff, gears and a rear locker will make it pretty capable and alot more legal.
Joe
 Posted: Sun May 14, 2017 10:55 pm |
Jimny diff won't just "bolt in" still needs fab work and is still made of cheese Have been out only a hand full off times but want to get out more and do harder/funner stuff and build it to be reliable and stronger.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Mon May 15, 2017 7:44 am |
You're almost better off buying that NT and leaving it NT bodied then trailering it out to tracks and beating the shit out of it. This way you're not paying rego, doesn't matter if you break it and you'll have more fun not worried about damaging your DD?
MrRocky
 Posted: Mon May 15, 2017 8:02 am |
I think its the nt spring spacing on wt diffs joe is after, you can build it tough enough for weekend thrashing and daily driving pretty easy in wa, theres not really the need for a bigger tyre than a 31 unless u drive mud puddles. You probably are better off buying a leafy and swapping motors then flogging the coily off. Dont get to caught up on the whole nt spacing on wt diffs thing you will run out of wheelbase before it becomes a relevant mod. Lockers, front chromos, gearing and 31"s will have u drive every track from bobs hill to the powerlines
Toomanycars
Joined: Thu Aug 18, 2016 1:47 pm Posts: 324 Location: Under a car in Brisbane scratching my head
Vehicle: Sierra g16 efi..and Sierra GTi
 Posted: Mon May 15, 2017 8:27 am |
We will soon have a coily soft top body going cheap... PM for pics etc...
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Mon May 15, 2017 11:18 am |
Joe it sounds like you were in the exact position I was with my Coily. I looked at heaps of options and the easiest (for me) was to build up a WT to suit what i wanted to do.
You could swap the bodies over but as the frame number is stamped on the chassis this would mean new rego. (For it to be tip top legal)
_________________ 31zook wrote: Makes me want something similar
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Tue May 16, 2017 12:41 am |
When I asked a few years back....
As far as dot are concerned, the chassis is the car no matter what body you put on it. To be legal you'l have to be regoed as the chassis. But you're not going to be legal anyway.....
