It is currently Wed Oct 21, 2026 12:38 am
Vehicle: 1995 Suzuki Sierra SJ70
Post Posted: Thu Jan 25, 2018 7:20 am
Been doing some work on my Baleno conversion lately and ran into the need for some ring spanners which I don't have a full set of as yet.
Just wondering for work primarily on the Sierra, and I also have a Hilux now, would offset or flat ring spanners be the most useful?
Post Posted: Thu Jan 25, 2018 8:10 am
Flat. I have a couple of offsets just because I collected them over the years, but where access is tricky flat works best.
Post Posted: Thu Jan 25, 2018 8:47 am
With 10,12,14,17 flat spanners you can pretty much consider your sierra tool kit complete. A 10mm pipe spanner can be handy for brake lines but not a necessity
* unless your zook was a farm car in which case ol mr farmer has probably added an assortment of imperial nuts/bolts into the mix ;)
Post Posted: Thu Jan 25, 2018 8:52 am
I use two sets, ring open ended to loosen, then ratch to take off.
bye
Post Posted: Thu Jan 25, 2018 9:00 am
A 10mm flare nut wrench for brake lines is absolutely vital, I'd suggest. I imagine Dave already has one though
Vehicle: G16b sierra
Post Posted: Thu Jan 25, 2018 9:50 am
Flat all the way, the long ones are pretty good. We have a set in the workshop that are flat but on a pivoting head, they're quite handy.
Post Posted: Fri Jan 26, 2018 6:52 pm
I use my offset ring spanners far moar than my ring/open end spanners
Post Posted: Sat Jan 27, 2018 12:12 am
Wot!! - Vice Grips not good enough for you?? :roll:
Post Posted: Sat Jan 27, 2018 8:34 am
I have 2 skinny 10mm i use for the task normally ;)
Post Posted: Sat Jan 27, 2018 8:54 am
In my opinion ya need all of them. I have stubby in flat and offset, long flat, normal lenth flat, flat ratchet, off set ratchet, flex head ratchet, open ended, ring, combo open and ring. Prob more but you can never have enough tools
Post Posted: Sun Jan 28, 2018 7:39 am
That's alot of tools Shep.
I have metric socketry, and flat open end / ratchet combo spanners.
For now I think I'll go for a set of flat metric ring spanners - but yeah the more the better if you can afford it.
Vehicle: Vitara 1994
Post Posted: Tue Jan 30, 2018 1:38 pm
So ball has a lot of tools to chose from...no excuses haha
Post Posted: Tue Jan 30, 2018 1:47 pm
Haha narh, I have more hand tools then ball. He has the big expensive tools.
Users browsing this forum: No registered users and 225 guests
