| Author |
Message |
davemcgrath
Joined: Sat Oct 30, 2010 8:14 am Posts: 81 Location: Geelong
Vehicle: 1995 Suzuki Sierra SJ70
 Posted: Thu Jan 25, 2018 7:20 am |
Been doing some work on my Baleno conversion lately and ran into the need for some ring spanners which I don't have a full set of as yet. Just wondering for work primarily on the Sierra, and I also have a Hilux now, would offset or flat ring spanners be the most useful?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu Jan 25, 2018 8:10 am |
Flat. I have a couple of offsets just because I collected them over the years, but where access is tricky flat works best.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Jan 25, 2018 8:47 am |
With 10,12,14,17 flat spanners you can pretty much consider your sierra tool kit complete. A 10mm pipe spanner can be handy for brake lines but not a necessity * unless your zook was a farm car in which case ol mr farmer has probably added an assortment of imperial nuts/bolts into the mix
_________________ ...
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Thu Jan 25, 2018 8:52 am |
I use two sets, ring open ended to loosen, then ratch to take off.
bye
Gwagensteve
 Posted: Thu Jan 25, 2018 9:00 am |
A 10mm flare nut wrench for brake lines is absolutely vital, I'd suggest. I imagine Dave already has one though
Kfal
Joined: Tue Oct 31, 2017 3:37 pm Posts: 84 Location: beyond the 26th
Vehicle: G16b sierra
 Posted: Thu Jan 25, 2018 9:50 am |
Flat all the way, the long ones are pretty good. We have a set in the workshop that are flat but on a pivoting head, they're quite handy.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Jan 26, 2018 6:52 pm |
I use my offset ring spanners far moar than my ring/open end spanners
missmyljdaze
Joined: Tue Jul 05, 2011 7:16 am Posts: 2323 Location: perth
 Posted: Sat Jan 27, 2018 12:12 am |
MrRocky wrote: With 10,12,14,17 flat spanners you can pretty much consider your sierra tool kit complete. A 10mm pipe spanner can be handy for brake lines but not a necessity * unless your zook was a farm car in which case ol mr farmer has probably added an assortment of imperial nuts/bolts into the mix  Wot!! - Vice Grips not good enough for you??
MrRocky
 Posted: Sat Jan 27, 2018 8:34 am |
I have 2 skinny 10mm i use for the task normally
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat Jan 27, 2018 8:54 am |
In my opinion ya need all of them. I have stubby in flat and offset, long flat, normal lenth flat, flat ratchet, off set ratchet, flex head ratchet, open ended, ring, combo open and ring. Prob more but you can never have enough tools
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
davemcgrath
 Posted: Sun Jan 28, 2018 7:39 am |
That's alot of tools Shep. I have metric socketry, and flat open end / ratchet combo spanners. For now I think I'll go for a set of flat metric ring spanners - but yeah the more the better if you can afford it.
vet 180
Vehicle: Vitara 1994
 Posted: Tue Jan 30, 2018 1:38 pm |
shep wrote: In my opinion ya need all of them. I have stubby in flat and offset, long flat, normal lenth flat, flat ratchet, off set ratchet, flex head ratchet, open ended, ring, combo open and ring. Prob more but you can never have enough tools So ball has a lot of tools to chose from...no excuses haha Sent from my iPhone using Tapatalk
shep
 Posted: Tue Jan 30, 2018 1:47 pm |
vet 180 wrote: shep wrote: In my opinion ya need all of them. I have stubby in flat and offset, long flat, normal lenth flat, flat ratchet, off set ratchet, flex head ratchet, open ended, ring, combo open and ring. Prob more but you can never have enough tools So ball has a lot of tools to chose from...no excuses haha Sent from my iPhone using Tapatalk Haha narh, I have more hand tools then ball. He has the big expensive tools.
